front prop drive flange
need the flange to go on the front of the transfer box, mine has one which is much to small to join the prop
still need one
John Roach
Post by John Roach »
I've a gearbox I keep as a spare. I know very little about these but assume flanges don't easily wear out. This being the case, and they're easy enough to remove, me thinks I can help. Might not be til next weekend though.
Regards,
John
1982 Stage 1
1982 88"...dormant in back garden!
if you wouldnt mind, flanges arent generaly a wearing part,
if it is a stage 1 item it will be about 12.5cm accross ,
if you would be prepared to sell, how much would you be looking for (in no rush, to actualy get the part)
thanks
Alex
John Roach
Apologies for delay in response...hope to have it off tomorrow.
Regards,
John
1982 Stage 1
no rush, the stage 1 is now sleeping under a sheet at home while im at uni,
how many ££'s ...ill see if i cna sort collection, may need to post though
Will you want a normal flange to replace it (then you wont have an open end to th egearbox and can keep it filled wiht oil ...)
bump...still need one
