rear prop length
rear prop length
can someoe measure between the gearbox flange and diff flange please, trying to find a prop so knowing the lenght will be useful (anyn know if a 101 prop fits - ive got a new one that came with the LR)
DPuckey
Post by DPuckey »
Had my prop develop a lot of wear recently, sods law I replaced it with a second hand one which was fine for a few weeks and then started to vibrate as well.
Sent the old one to Reco Prop, http://www.reco-prop.com/ who used it to make me up a new one for around £250.
I had already checked to see if any were in stock, none at Landrover and if they had been then the last stock price was around £400.
Checked and no other prop seems to be the same length.
Hopefully they still have the dimensions, if not I have an old one you could have to get them to copy again. Pleased witht heir work and my garage man ahs used them before for custom triallers etc.
They can recon your old one if you have it, but mine was pretty worn so would have been about the same price
thanks...ill keep looking for a second hand one before going that route...could do without having to spend that much ....have a hope atm that a 110 V8 with the LT95 will be the same ...hopefully
Andy Dawe
Post by Andy Dawe »
If it's a rear I have one in my garage that has done 20k miles.
Any use to you?
yes very much use ...how many ££'s
Andy Dawe
Post by Andy Dawe »
email me I'm sure I can help you out :D
sorry didnt get arround to doing anything with this
currently have a 110 V8 sat here
if someone could measue the fitted length of one it would be muchly appreciated
If this one wont fit then ill be intouch about the Stage 1 prop
still stuck on the rear prop...need to know the length of a stage 1 shaft (extended and when compressed) if anyone can measure one
casamercedes
Post by casamercedes »
5988 wrote:still stuck on the rear prop...need to know the length of a stage 1 shaft (extended and when compressed) if anyone can measure one
I have measured the rear prop for you and the closed length is 100.5 cms and the extended length is 105.5 cms. These measurements are flange face to flange face.
Dave
2004 LDV Convoy Crew Cab 2.4 TD
2005 Zsara Picasso HDI (cheap to run)
thanks very much
Davo
Post by Davo »
A big thanks from me, too, as I needed that information as well! Now I can send a 4-cylinder prop away to be changed. :D
