how does it work
ive got the little bits on the stalk that look like they should push onto something to cancel the indicators, but theres nothing obvious on the column to do that,
neither the tacr or stage 1 have anything on there columns....is there something that bolts on?
Standard 119 SA switch. There is a metal cancelling lug as part of a steel tube. This goes on the end of the column along with a spring and turns with the steering wheel.
