Engine Swap
sebking
manifold fixed
Post by sebking »
Gaskets now on correctly.
Also to note! the pin on the water pump that faces with the pulley was slightly over size so when I tightened up the fan it pushed back through and jammed the pulley! - Watch out for this on third party pumps...
Need a new lead for no8 as in my excitement managed to get it caught up in the fan belt :(
Once that is sorted I'll get it all timed up, check that it moves up and down the drive way (make a film) and then swap in the nice new carbs.
sebking
manifold
Post by sebking »
well having broken the manifold, removed the EGR, fixed some pipe work and nearly there with the replacement manifold here's some pictures!
http://www.landroverv8.com/v8/
Well done so far. Those carbs do add a bit of bling :D
Thought you were older too :P
sebking
older
Post by sebking »
That's Oliver aged 10 - very useful :)
"Take that manifold off while I put the kettle on"
sebking
moves!
Post by sebking »
moved out of the garage and around on the drive!
treated it to a wash, sorted the seat runners, put new seat belts in. Now for a horn and to book an MOT!
Kippa
Seat belts
Post by Kippa »
Hi Seb,
Did you install inertia seat belts, if so what fixings did you use?
Cheers,
Kev
sebking
belts
Post by sebking »
standard kit from Sams Trim - Securon I think.
