uploading photos
noexitroad
uploading photos
Post by noexitroad »
can anybody tell me how to upload photos from photobucket using a mac pc?
5988
Have you got your pics on photobucket already?
If you have then all you need to do is copy the IMG code (4th line of code under the picture) and past it into your post
As per previous, all you are doing is putting an automatic link into the posting. Photobucket provides this once you have uploaded your pictures to their site.
If you copy the wrong line from photobucket all you get is the link appearing in the listing. In which case you have to go back, edit the listing and insert the other link in its place. Then the picture should appear in the posting as soon as someone opens it.
Annnd, it does matter if you're using a Mac or PC, the code is the same. I use a Mac mostly and sometimes a PC.
