Battery box lid
Thanks for all the replies.
David,
The pictures show what I expected to see. I have neither the lid or the catch and there is no sign of a catch ever being there. The top of the seat box is worn though so it looks like something has been covering the battery at some point and accessed a fair bit.
Tel,
All crimbo pressies are greatly received but there are no holes/fittings where that type of lid could attach so I dont know if it would fit?
David,
Tel,
I'll do a pic
Will do a pic and upload it
Seb
Seb
The photo on DB’s post is correct for the Stage1
The retainer clip and the two rivets are available from LRSeries
http://www.lrseries.com/shop/product/li ... 388&page=1
http://www.lrseries.com/shop/category/s ... =ru608123l
I can’t help you with the lid but the part number is MRC6969 and yes it is unique to the Stage1. Maybe someone has got a second hand one lying around but if all else fails one could be easily fabricated from a pattern.
Good luck…
Good luck…
The latch on the LR link is 110. Though possibly the last Stage Ones as well. Probably easily assessed by whether your car has pop rivet holes or not.
Otherwise it's a tongue at the rear and a cheap and nasty knob and rotating tongue at the front. Therefore no holes in the seat panel in order to retain the battery box's lid.
latch
that is the latch I have.
Phone just died so pix need to wait.
Lid pix to follow!
The lid is also held on just under the seat with an ali strip.
Lid pix to follow!
pictures
