Rear Sailsbry oil seal
My Stage 1 Passed the MOT on Friday, No Advisories
On Saterday the rear Diff oil seal started to leek, is it a big job to swap out, it looks a fair bit more involved than a standard Rover casing
Aidan
Aidan
1982, Stage 1 SW LPG
1999, Disco 2 4.6 Stage 1 Heads ES Multipoint LPG
1976, 88 SW
1973, 88 Truck Cab
1976, 88 SW
1973, 88 Truck Cab
The Salisbury is a bit different for this job in that you must mark the position of the pinion shaft, retaining nut, and flange, and then count the number of turns it takes to completely undo the nut. This is so that it will all go back together without putting more load on the collapsible spacer that sits between the two pinion bearings. If you did overload then you'd have to replace it.
They still seem to leak, though. I replaced one seal and it just leaked a little less than the old one . . . and also bought a new axle and that's leaking now anyway!
The key to stop them leaking is to replace the flange,
I had one that I had sleeved all looked good but it still leaked within a few hundred kays, replaced it with a brand new one and its been going for the last 3 years without issue.
There are also heavy duty seals that help a lot of the aftermarket stuff you buy in Australia is crap.
5988 - Cool I will drop you a PM next week
Thanks for the input, Its the collapsible spacer that worries me, but if I do it carefuly it should be ok...
Is it worth a gen seal?, I patten parts in the UK arnt great either
anyone got a part number to hand?
Aidan
Aidan
1976, 88 SW
1973, 88 Truck Cab
1976, 88 SW
1973, 88 Truck Cab
OH CRAPDavo wrote:The Salisbury is a bit different for this job in that you must mark the position of the pinion shaft, retaining nut, and flange, and then count the number of turns it takes to completely undo the nut. This is so that it will all go back together without putting more load on the collapsible spacer that sits between the two pinion bearings. If you did overload then you'd have to replace it.
ill be doing that again then
or just run it an see how it goes ....
Oil seal for the Salisbury axle is AEU2515 and is available in either genuine or pattern from www.lrseries.com
