I've a gearbox I keep as a spare. I know very little about these but assume flanges don't easily wear out. This being the case, and they're easy enough to remove, me thinks I can help. Might not be til next weekend though.
if you wouldnt mind, flanges arent generaly a wearing part,
if it is a stage 1 item it will be about 12.5cm accross ,
if you would be prepared to sell, how much would you be looking for (in no rush, to actualy get the part)
thanks
Alex
no rush, the stage 1 is now sleeping under a sheet at home while im at uni,
how many ££'s ...ill see if i cna sort collection, may need to post though
Will you want a normal flange to replace it (then you wont have an open end to th egearbox and can keep it filled wiht oil ...)
