Whilst I have been rebuilding my station wagon, I have been considering fitting of power steering.
It would seem to be a lot easier than trying to do it on an ordinary Series 111.
Has anybody done this and what parts did they use?
All info greatfully received
Dave
Fitting power steering to Stage 1
2004 LDV Convoy Crew Cab 2.4 TD
2005 Zsara Picasso HDI (cheap to run)
The only legal conversions use a straightforward clamp-on system with remote rams. There are least two kits available that are intended for Ser III.
Otherwise you have to modify chassis and bulkhead. I haven't seen or read of one conversion yet that actually addressed the legal/safety/insurance aspects as part of the conversion.
Been posted on here before, but here you go
http://www.expeditionlandrover.info/PowerSteering.htm
Have only heard good things about this company's products (formerly TI Console). Not sure if their kit fits a Stage 1, though they claim it fits all Series, and they are familiar with Stage 1's. Bit pricey, mind.
http://www.heystee-automotive.com/
Regards,
John
Regards,
John
1982 Stage 1
1982 88"...dormant in back garden!
Thanks for that and I have been in contact with them before, but as you say they are VERY expensive. The kit does fit the Stage 1 as well as the standard series vehicles.John Roach wrote:Have only heard good things about this company's products (formerly TI Console). Not sure if their kit fits a Stage 1, though they claim it fits all Series, and they are familiar with Stage 1's. Bit pricey, mind.
Regards,
John
Regards Dave
I looked into this seriously.
When Chris Perfect was UK distributor for the power steering kits. I contacted him and had a very long conversation on how the ram kit from T.I. fits.
The kit is designed to fit a 2.25 petrol or diesel and early 2.5s. The stage one's front cross member fouls the ram and therefore the cross member needs cutting out and repositioning. The pump supplied in the kit is a low volume pump with a large capacity reservoir. Modern pumps such as the ZF can produce tool much pressure as blow ram seals. According to Mr Perfect a blown ram seal is unheard of and they wont warrant your use of non kit parts.
You can fit a pressure reducer but this all adds cost and T.I. at that time would not sell individual parts ie ram and brackets.
I also looked into fitting a defender system and somewhere on this forum is a good magazine article on how to do it.
Good luck keep us posted.
