Some General Questions
5988
As im missing virtualy everything that should live under a S1 bonnet-
Does a Radiator from any other landrover fit? how does it attch to the vehicle-is there a frame for it or does it bolt directly to the front?
What should the air cleaner/intakes be like. Some seem to be like the RR set up and others have a big can with some piping to the carbs-did they change at a set time?
Do they have a mechanical fuel pump on the engine? or electirc somewhere
how much different is a RR engine, as i have access to one from a 81 RR that seems reasonable..hoping to get the proper engine but PO says its dead
could someone get some under bonnet pics so i can see where everyrthing goes...ive got 2 empty wings and nothing on the bukhead..no front pannel or engine, so no idea what should even be there
can exhaust sytems be got from anywhere?
oh and the S1 is an 81 as well
You haven't said which model Stage One you have. This will determine the answer to some of the questions.
I think you should start by downloading the parts list from this site. Then check the VIN break down.
Radiator is unique but I suspect the core is common with something else. Sits on pegs and grommets.
Electric fuel pump.
Engine is generally the same as concurrent low compression Range Rover. Once again, you haven't stated what model Stage One you have.
Exhaust systems depend on where you are in the world. Australia is a joke, in the UK everything is on the shelf with a choice of brands.
5988
Its a Utility, from 1981
im in the Uk
Bumpkin
Post by Bumpkin »
Hiya
Pretty sure i have a rad from a petrol 90 in mine. I put a piece of Dexion along the bottom to pick up the bottom pins and fixed the top with M6 bolts. Its a bit taller as the bonnet stay has worn a grove in the brass filler bolt on top of the rad.Works a treat and not 250 POunds.
Rob
Post by Rob »
the electric pump in underneath on the chassis by the gearbox
Larosto
Post by Larosto »
Image[url]
`hope it helps.
Horst
5988
landdani
Post by landdani »
Hi, did you see the section: introduction and photos? Their is a lot of usefull photos.
try olliebarrett_92
and John Roach at http://s455.photobucket.com/albums/qq27 ... %20bought/[/list]
wonderful sport!
choc-ice
Post by choc-ice »
Where are you? You're welcome to have a look under the bonnet of my Stage 1 in Luton
olliebarrett_92
Post by olliebarrett_92 »
WOOOOO! I have been mentioned ^^^ to help someone!! hehe!
I can take some more picture of mine under the bonnet if you would like, however, I'm not entirely sure that it is all in the correct place (for example my washer bottle isn't mounted at all, and is just shoved under the wing! As long as it doesnt go anywhere that'll do!)
Ollie :)
Now on the road, and loving it!!!! =)
5988
landdani wrote:Hi, did you see the section: introduction and photos? Their is a lot of usefull photos.
try olliebarrett_92
yes i did see the ection but alot of posts to awl through if i dont know where they are
for now ill not be putting the front back together...not even got an engine yet.....or a repaired chassis....or bulkhead :roll:
Strongly advise that you grab the Series III Owners Repair Manual and a copy of the Series III V8 Supplement. All available from this site.
They will tell you what needs to go where and includes a number of variations too. Then if need it, grab the Parts Catalogue.
landdani
Post by landdani »
I am having internet problem with the manuals part. :? :x
wonderful sport!
5988
me to ive been using the ones here
http://www.landroverv8.com/
landdani
Post by landdani »
Look at thes photos, I hope that they will help, they are from this club anyway, thank for the owner.
[/img]Image
[/img]Image
[/img]Image
[/img]Image
[/img]Image
Image[/img]
wonderful sport!
