Ok, the mechanic has had my Landy now for over 3 weeks, and he has only just started work on it.
This is just the start of my problems! the carbs the I had put on them so that it would pass its Hyrdocarbon emissions test are not working properly.
With my 17th birthday on Monday it leaves me 3 1/2 days for him to get my car working!
If anyone has any carbs, preferably SU's, that they know work, PLEASE leave a message.
But for now, I will tell him to make those ones work!!
I will keep you posted!
Ollie
This is getting silly now!!!
Now on the road, and loving it!!!! =)
Carburettors are fairly simple, when you say they're not working what do you mean?
Would a rebuild kit sort you out?
Beware that most garages now don't have mechanics that have seen a carb, let alone two, let alone worked on them. Have you tried a Land Rover specialist, or even a motorbike specialist to get them balanced? My last bike had 4 carbs and balancing them was part of the 4000 mile service.
are you sure it is the carbs?
Backfire sounds like timing and that area.
Re: This is getting silly now!!!
If you don't mind me asking, which garage have you taken it too??olliebarrett_92 wrote:Ok, the mechanic has had my Landy now for over 3 weeks, and he has only just started work on it.
Ollie
bb
