I think someone was asking about this a while ago and I think no-one could say for sure which vacuum hose goes where.
I'm in the middle of wrecking an old Range Rover so I made sure to check before I took it all apart.
On the back of the difflock switch, there are three little pipes. If you hold the switch so that the knob is facing up, they are spaced so that the top one is off to the left a bit, the middle one is off to the right a little, and the bottom one is to the left.
The top pipe is connected to the front of the difflock actuator, the middle pipe goes to the engine, and the bottom pipe is attached to the back of the actuator.
I hope this helps someone!
