Arrrgh I've put diesel in the V8 !
Kippa
Post by Kippa »
Don't ask me how as I'm still trying to work it out myself . . . anyway I put £30.00 of diesel in an empty tank, drove it 500 yards home then loads of white smoke :cry:
I've drained the tank; now my friend has 20 litres of fuel for his oil heater!
I then disconnected the pipes from the fuel filter and drained them.
Cleaned the spark plugs. Anything else?
I’ve searched the web but can only find advise regarding filling a diesel with petrol.
Please feel free to berate me, I’ve only been driving for 25 years and don’t even own a diesel vehicle!!!
choc-ice
Post by choc-ice »
Don't worry about it, it's an old trick for unsiezing stuck valves. Refill with petrol and drive on, the smoke will clear quickly
sebking
don't panic
Post by sebking »
empty tank, clean fuel lines, fill tank.
Drive.
Snigger at the thought of how much it would have cost to get a modern car fixed if you had done this.
Kippa
Diesel in V8 !
Post by Kippa »
Guys,
Thanks for the advice, engine started, loads of smoke as predicted but it was ok because it was bonfire night!
Unfortunately I’ve now got a fuel leak. Petrol is coming from the pipe that enters the fuel filter; I’d previously disconnected it to drain the diesel.
I disconnected the pipe again and found that the bulbous end of the pipe had worked loose. I pushed it back on the pipe, it seemed secure and tight, and reconnected everything but alas it’s still leaking.
Do I need to replace the steel pipe that’s attached to the fuel hose?
Kev.
sebking
Post by sebking »
old hard rubber pipe gets disturbed, result leak.
I'm not quite sure where you problem is but it's probably just a bit of hose needed (and some clips - I'm never confident of push fit fittings where there is flammable liquid!)
Kippa
Post by Kippa »
It's the steel pipe that enters the fuel filter housing from the left as you look at it (from the fuel pump).
It's got a hollow nut that holds the pipe in place.
Someone recommended plumbers tape !
glencoyne
Post by glencoyne »
Sounds like you have either got a piece of dirt in the connector, or you have overtightened it and cracked the filter housing. If the latter, PM me, I have one attached to a bulkhead. I robbed the filter bowl off it for another vehicle, and it isn't much use to me as it is.
Richard
Andy Dawe
Post by Andy Dawe »
kippa.
Has the black hard plastic pipe pulled off the metal pipe (which screws into the filter housing Glencoyne is on about)
If so the black pipe is a standard size available from most motorfactors. You can heat it up (gently) and make up a new pipe pushing the old metal fixings into the heated pipe. Or see if Craddocks have one. It wont be cheap but peace of mind.........
Kippa
Fuel leak
Post by Kippa »
Hi Andy,
If you look at the bottom right picture on page 7 of your website, it's the steel pipe that enters the fuel filter that's leaking. The nut is a hollow one that the pipe passes through. On the end of the pipe is a rounded funnel that the hollow nut tightens up on and seals the pipe in place.
Unfortunately the rounded funnel is loose so when the nut is tightened it comes off.
Kev.
Kippa
Fuel leak sorted
Post by Kippa »
Thanks for the advice, it turned out to be an olive that wasn't sealing properly, total cost .55p! Unfortunately I've had to use a metric one as nobody seems to sell imperial ones anymore . . . unless someone knows different?
