ok, I use my stage 1 off road very regularly, & in about 60,000 miles I have been though 2 sets of shoes & 1 set of wheel cyilinders!!
Now it's pulling shaply too the left!!! DAMIT
also recently had leaky frount slave cylinders causeing the warning light to come on!!
thoughts?
"The very difficult we do immediately the impossible takes a little longer!"
1985 Range Rover V8 Auto [Rachel]
1981 Stage 1 V8 S/W [Custard]
1972 SIII 88" D S/W [The 88"]
That warning light should be the Dual circuit pressure thingymajigwassicallit switch coming on as you have lost pressure in the system. and the valve has moved to prevent more fluid loss and allow braking on the other circuit.....
Now you got the fun of resetting it when you fix it.
