Power steering mod
Power steering mod
I've been thinking about doing a power steering mod to the stage 1. I can get an early 4 bolt rangerover box, pump, reservoir and hoses for NZ$200. By the looks of things, with a small chassis mod at the front crossmember, and some lining up for the steering box, a mounting bracket for the pump, it should be a piece of cake.
Any thoughts, hints, or otherwise would be appreciated muchly.
Stop Global Whining.
Cheers. Not too much of a problem to modify the inner wing. The hard bit will be recessing the front crossmember and strengthening it, and also the mounting point for the steering box will probably have to be strengthened. The expensive bit will be getting a modification certification for it all.Andy Dawe wrote:I had a serious look at this the steering rod that goes from the end of the steering column to the PAS box needs more room than the inner wing provides you will have to fit a defender inner or cut the inner about to let it turn.
Unless of course, I just take it to the friendly mechanic down the road who would never know that p-s is not standard in a stage 1.
Interesting, primsil. Did the shaft out the bottom of the box line up ok? I looked at that, but thought that I would have to take a couple of inches out of the front xmember.primsil wrote:I fitted a 4 bolt box to the chassis I scrapped, just had to remove the bracket the relay mounts to and drill and sleeve the holes in the chassis. didnt recess the crossmember at all.
How did it work out for you? All good?
And cheers for that bit of info!
Don't know if you've managed to do this mod yet, but there was an article in LRO some years back (probably about 10 years!) about how to do this to a series vehicle using RR parts.
If anyone has the back issues, they may be able to find it for you (sorry, mine got thrown in the skip when I moved house).
Power steering pump for v8
How did you go fitting the powersteering pump? Can you just grab one off any rover v8? Any modifications/pulleys/brackets needed to fit it?
I am definitely going to fit power steering but will probably use a two-way ram rather than a range rover box.
Geoff T
1 x Ex-ARMY ragtop ("Major"), 1 x Cab/chassis project ("Hefty")
