Gents,
Due to being let down, with a promise of the use of a shed to undertake a chassis change, I have now had to re-think my plans, unfortunatly lack of facilities mean that my Stage 1 has to go. Mechanically he beast is nearly completed with hosts of new components being fitted (including LT95 with overdrive , new brakes (pipes cylinders drums and shoes) Re cored radiator and even replacement C.V Joint (fortune on its own.) The bulkhead needs new footwells, and idealy the chassis should be replaced. I am hoping to recover some of the money that I have spent so far, however this is a very good staring block for somebody that has the facilitys to undertake this job. I have re- chassised several landrovers in the past, and I had a superb workshop, however not where I am living now.
Reply to advert or send a P.M. for further details. Vehicle in Cornwall
Regards Cat 3412
Stage 1 V8 STATION WAGON spares or repair
I'm going to add my little bit here.I sold Phill this engine/box and overdrive so i can tell you that its a goodin.If he breaks it i will have the Overdrive back for the R/Rover. I have also seen the very high quality of his work, so any work he had done will be Mint!
Terry
Terry
