I need to replace my facet fuel pump as it sometimes needs a whack to get it going.can anyone tell me if it should be a 1.5-4psi or a 4.0-6psi please
Thanks Matt
Facet fuel pump psi
Re: Facet fuel pump psi
Manuals say 31 KNm2 Pressure (static) - which is 4.5psi
It's actually not a FACET but they are virtually indistinguishable and interchangeable.
From memory there is little choice if you look in their catalogue, once you have the correct design and voltage.
I can't remember the correct brand but they are available and frequently cheaper than FACET.
Bendix
https://www.ebay.com.au/itm/Land-Rover- ... 1438.l2649
Though they do eventually fail, it can be worth checking the internal filter before condemning the unit.
Original Land Rover part number is PRC3343 , superseded by PRC3901 apparently
http://www.lrseries.com/shop/product/li ... amp;page=1
Seems to be plenty of choice out there from many suppliers for various prices
