Hi everyone,
well… 5 months into 109V8 ownership and I've nearly got everything I need to recommission my old Land Rover which had been stripped of most of the unique 109V8 bits when I got it. Its been difficult gathering the parts (was little things like gearbox mounts and throttle pieces that took the most time - ended up getting these from Germany. Even managed to gather every one of the parts needed to build a front axle trough a combination of used and NOS parts - I must know the parts catalogue by heart now!), but totally worth it as this vehicle would definitely have been broken up if I hadn't been able to find the bits (big thanks to forum members who helped me)
The only bits I still need are:
1) A seat base (as long as the front is OK I can rebuild the rest)
2) A passenger-side floor plate (ideally a drivers side too)
If anyone can help, please let me know. I live in the Manchester area so can travel locally to collect or could arrange a courier or forum relay to collect.
Many thanks indeed.
Wanted: Seat Box and Floor plates(s)
Re: Wanted: Seat Box and Floor plates(s)
have u got a steering box now tried to e mail but couldnt, ripon coming up prob get a seat box there will a defender one do or a series
Hi - no pm came through no. Still looking for a steering relay, I have the original but as mentioned, it's suffered a bit of damage - repairable but would prefer a replacement.
Yep - if all else fails I'll pick up a 110V8 seat base but would prefer a proper 109V8 one.
Ripon has been cancelled sorry. Even caught LRO out... Live strikes again!
EDIT - its Ripley Castle that is cancelled - LRO Spring Adventure. Sorry! Ripon 4x4 spare day is still on
Couldn't you make up some footplates? Shouldn't be that difficult to make templates out of ply or similar?
Good luck with the recommissioning!
Thank you. Yep - floor plates would not be a problem if I had a pair from which to make templates - similarly I can buy a complete, uncut, seat box front from YRM and could change a 4-cyl one to 109V8 spec, but would need a template. I'd prefer to find the real thing if I can as I'm aiming for quite a high standard on this (my third) build. I could just make some to fit but suspect I'll miss some detail if I do.
you going to rippon skittles
I can't make it unfortunately, I have something on that weekend (though if my plans change I will be there)
did you go to penrith autojumble bought a few good bits coffe can resevoir, deep s2 skirts sides of a series 1, 2 avon road master wheels n tyres. s1 oil filter bloke selling a load of stuff cheap he had 2 petrol engines 25 quid each.
