I'm along way off needing doors , but out of interest ( and incase I see some for sale) I assume they are one piece items??? If they are one piece, can the S11 (11A) SW two piece doors be used?????
I only ask, cos they are like hens teeth and there is a firm that has started to sell the lower door and soon will be making the tops to match?
Nuggs
Second Row Doors
Second Row Doors
Richard
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
Re: Second Row Doors
Sounds very interesting with the middle row doors - what Company is it ?
Michael
1965 109 FC SIIA
1982 109 V8 SIII CSW Stage One
1982 109 V8 SIII HCPU Stage One
1990 RRC Vogue SE
1965 109 FC SIIA
1990 RRC Vogue SE
Its a firm called SPlandrover.
As has just been pointed out to me , they won't accomadate the anti burst lock ( nothing that a hole saw won't cure) .
So long as they start to sell the tops to match they could be a usefull solution.
Nuggs
Nuggs
Richard
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
Ah ok - found them
http://www.splandrovers.com/LAND_ROVER_ ... /sp524.htm
Unfortunately it doesn't look like they're going to make them galvanised
Michael
Michael
Michael
1965 109 FC SIIA
1990 RRC Vogue SE
1965 109 FC SIIA
1990 RRC Vogue SE
Unfortunatley no but drill and fill with cavity wax and a good paint job should see them last??
Richard
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
Not on the salty Winter roads of Denmark
Michael
1965 109 FC SIIA
1990 RRC Vogue SE
1965 109 FC SIIA
1990 RRC Vogue SE
Apparently they are going to make them to facilitate the anti burst lock so perhaps they will galv batches of them too.
Richard
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
1982 V8 109'' SW
1982 2.5n/a 88''
1999 V8 D2
Ashtree Landrover will also make Series one-piece second row doors and two-piece second row door bottoms as a special order, and they will galvanise the frames. On my enquiring about two-piece second row door bottoms (which aren't mentioned on their website) they said, "We do supply those half doors for the alloy tops. The cost is £150.00 per door plus vat and delivery. This is for a galvanised framed door finished in etch primer and marine bonded skin. This is a very high quality item" (I didn't ask about tops, as I have a pair of solid ali second row door tops from an early 110 I want to use)
http://www.ashtreelandrover.com/Doors.html
Excellent info - thanks Geoff
Michael
1965 109 FC SIIA
1990 RRC Vogue SE
1965 109 FC SIIA
1990 RRC Vogue SE
