West Aussie Stage 1
Greg White
West Aussie Stage 1
Post by Greg White »
Hi Folks
I am the proud, allbeit recent owner ove a series 3 stage 1 Land-Rover.
I am mostly enjoying the experience apart from the fuel bills and an ongoing tuning issue that i am having .
I live in the South West of Western Australia.
Managed to get the landie out into the bush a few times now. Mainly Sw west and South Coast. I am planning a trip out to Kalgoorlie ( red Desert country) in the next couple of weeks
The Rover is an Australian built 1982 Series 3 Stage 1, 3.5 ltr V8, constant 4x4 Station Wagon with safari roof. Its pretty original apart from a electronic ignition system and upgraded front axels that I have fitted.
ever noticesd that 4X4 and $X$ require the same keystrokes?
I have heaps of jpg's. cant find how to post them.
Regards Greg
[/list]
jonnyboy
Post by jonnyboy »
Hi Greg, Welcome to the forum.
If you want to post pictures you will need to upload them to a website first. Photobucket is used by a lot of people.
Once you have your pictures uploaded, right click one and go to its properties and then copy the Addreess (URL). If you then paste that address into your message between image tags [img]and[/img] the pictures should appear.
Does that make sense?
Jon - M1CQO
My Website
arcticrover
Post by arcticrover »
Hey weren't a lot of the Australian Stage 1s fitted with LR approved 4.4 V8s? I seem to remember reading about that in the Series III Performance book . . .
Greg
Welcome to the forum. Members from every corner here.
terry
Greg White
Thanks for the welcome folks.
The engine varriant that artic rover mentions probably from a leyland P76.
My Land-Rover V8 Supplement "repair Operation Manual Supplement (1981) doesnt mention any other V8 other than the 3.5 ltr Rover.
The P76 was a large Australian built sedan, renowned for its unreliability , poor build quality, and that you could fit a 44 gallon drum in the boot. which was handy given the fuel economy.
There are P76 clubs in Aust for total masochists with to much money.
speaking of masochism, my landy has just returned from the local Land Rover dealer no better than when i took it there.
It has been running very rough, I thought this must be a distributor issue so i replaced the points with a optical electronic system,. Cleaned the fuel filters, adjusted the timing , changed carb diaphrams. still no better so i bit the bullet and sought professional help.
They think that the zenith stombergs need overhauling.( they cant find any other cause for the performance problem)
So the issue is now , whether to persist with the strombergs or convert to another system.
That of course throws up the issue of originality . At the momment I just want the rover to go so i can get out there and enjoy it.
Any thoughts gentlemen?
Also found this excellent site that may be of interest http://www.csse.monash.edu.au/~lloyd/4/LandRover/
Thanks and regards Greg
Exactly what do u mean by running rough?
tel
Kiwistage1V8
Post by Kiwistage1V8 »
Yep. 4 barrel holley and a manifold to suit.
easy to tune, and better fuel economy than the twin stormys
I slapped a 465 holley and edelbrock performer on mine, and have been pleased as punch with the results
Alternatively, the Buick 215 (rover 3.5 in disguise) came out with a twin throat downdraft carby. I am sure that the 350/500 holley 2 barrel would go straight on.
Stop Global Whining.
foggydave
Post by foggydave »
I have just put a 4 barrel weber on mine
More grunt
Better mpg
Far more responsive
Remember though that the exhaust will need uprating as all that air going in has got to get out.
Regards Dave
Ginga
Post by Ginga »
foggydave wrote:I have just put a 4 barrel weber on mine
More grunt
Better mpg
Far more responsive
Where did you get them from?
How long did it take you to fit them?
Any Problems?
The big one - How much???
Regards
Ginga
Theres always a way !
jonnyboy
Post by jonnyboy »
I have looked into fitting a 4 barrel carb before and got put off by the price. You are looking at £4-500 for the carb and manifold. You may be able to get it cheaper from the states where these are more common.
Jon - M1CQO
My Website
foggydave
Post by foggydave »
I was really lucky ( in the right place at the right time)
A mate was going to uprate a V8 in an old MG but never got round to it, then ran short of cash soooooo
1 brand new 4 barrel Weber
1 Edlebrock manifold
1 Real Steel high lift cam
1 set Rhoades lifters
All for £200
Also just bought a crane off him for £50
Does,nt happen often.
The Weber and manifold fitted ok but had to buy a special thermostat housing from RHP
Ran perfect first time but took it to my mates garage who just adjusted the mixture a tad
Webers seem to be recommended over Holly carbs as they stay in tune better
MPG went from 14 mpg to 17mpg although there is a great temptation to just floor it at times Given the cost of buying brand new off RHP or Real Steel etc I don,t think I would have done it but at £200 could not resist.
I have not fitted the cam or lifters yet as I am trying to get hold of a 3,9 engine and make it all worthwhile power wise as I have a low comp 3,5 engine at the moment.
Just fitted tubular manifolds and chopped a Range Rover exhaust to fit but have not run yet as I am doing new foot wells/front inner seals and other stuff etc so off the road for a few months.
mattv8
Post by mattv8 »
if your prob is that (only way i can explain it is as a stamer when u put your foot down or can run roughly) its a earthing fault. the best way i was told to sort it is to take a wire from the battery to a dash mounted switch then to the live side of the coil, no fues uesd, so when you turn on your ignition, flip the switch on n then start, when you turn ignition off youl have to flip the switch off to stop the engine, but i found it was a lot better. ive also put in a fuel pump cutt off switch, for sev resones, you can work on things tha need the ignition on n not have the pump gpin constantly n also if any thevin sod trys to nic your most pressious item, well they wont get far if the fuel pump isnt workin will they!!!!!
