Page 6 of 7
Re: some exotic Stage 1 in Germany
Posted: Mon Jul 12, 2021 8:00 pm
by FBW
disco2hse wrote: Mon Jul 05, 2021 7:52 pm ...Yours gives so much inspiration...
That pleases me...
it continues...
Completed the right front fender. The trained eye immediately recognizes that there is one missing "Nothing", so a hole! :)
Heating wasn't really necessary for Dubai. Therefore there is no hole where you can suck in air.
Cutting the hole isn't a big deal ... but, someone meant it well and reinforced the fender. With 6 mm allurized corrugation :?
... you could have thought a little.
Well, then we go to the operation and put on the flex ...
So that the paint didn't get too hot, I had to let it cool down every now and then.
...fits!
...the same procedure on the other side
Basic gynecological training is useful in order to tighten the top three screws on the sheet metal between the fender and foot box on the right. On the left, that doesn't help either. Then you have to come up with something ... :roll:
Sit!
... I think most series look worse on the top than the Sandy in the wheel arch! ;)
... and around the top it also makes an impression!
... but the list of to-do's is still long :o
What could be removed from the list?
The electrics in the engine compartment sorted. I converted the main headlights to relay control. I use the original line to control the relay. A new, thick line brings the electricity. This means that the power no longer runs through the switches or through the standard wiring harness.
Functionally it's wonderful, but I don't really like the solution (yet).
Then screwed on the front mask and grill. Unfortunately, the lower grill for the oil cooler opening is missing in the puzzle :?
You can't buy such a thing ... :o :? :D
The Sandy is now absolutely modern! I also installed a KERS system :shock:
Then the headlight inserts were installed.
The grill from the oil cooler has also gotten some color ...
... and then first ride !!
>>> https://www.dropbox.com/s/3gv3vvr4bl4zy ... y.mp4?dl=0 <<<
... I cannot yet say how it is to drive around bends. Item 35.> Mount the steering wheel <is still open :D
greeting Frank
Posted: Mon Jul 12, 2021 8:31 pm
It is more likely that it is off a LHD vehicle? Ours do not have holes on that side. The air inlet is on the other wing.
I have relays on the headlights. Gives the indicator stalk a much longer life span. But then mine is also 24V so the contacts tended to burn out that much faster too. :roll:
Posted: Mon Jul 12, 2021 8:39 pm
by FBW
disco2hse wrote: Mon Jul 12, 2021 8:31 pm It is more likely that it is off a LHD vehicle? Ours do not have holes on that side. The air inlet is on the other wing.
I know that. But my car is is LHD. But that's probably how it is when you buy cars with first delivery Dubai (!).
no heating lever, no switch for the fan ... not even the print above the switch! They really tried hard :P
... no heat exchangers, no Fan ...
... no holes in the fenders :?
greeting
Frank
Posted: Mon Jul 12, 2021 9:36 pm
Cool 8)
And a small safari roof. They are not common.
Posted: Tue Jul 13, 2021 6:36 pm
by FBW
disco2hse wrote: Mon Jul 12, 2021 9:36 pm Cool 8)
It was so optional. But it is very rare.
So far I've only seen one Landy with the truck cap tropical roof.
Final sprint
Tinkered struts for the fenders. To compensate for the heavy sliders, aluminum tubes were used here :D :roll:
Drawbar mounted.
I actually didn't want to assemble the Grab Handels in Limestone (!) At all. Unfortunately, I don't have the ones that belong to such a car and without them it looks very empty. So to everyone: >> it won't stay that way! <<
Mounted lower and upper tailgate.
The missing brackets for the Dormobile roof are also in progress ...
They are much better than the rubber bones
Oh yes, the assembly of a steering wheel extends the radius of action considerably
... outside of the garage the device really comes into its own !!
I hope you like the result...
greeting
Frank
Posted: Tue Jul 13, 2021 8:25 pm
by Mik
That's fantastic Frank !
Posted: Fri Jul 16, 2021 7:14 pm
by FBW
Mik wrote: Tue Jul 13, 2021 8:25 pm That's fantastic Frank !
Hello Mik,
I feel the same way...
Lookup
Sandy on the Road
(Pump Up the Volume :lol: )
>> https://www.dropbox.com/s/e98bugcmlmhvz ... I.mp4?dl=0 <<
As you can see in the video, the Sandy is not that unwieldy to drive .... o.k. I still have to practice at the entrance to the courtyard :D
greeting
Frank
Posted: Fri Jul 16, 2021 8:40 pm
Absolutely brilliant. I wish that I could see it in the flesh.
Posted: Sun Jul 18, 2021 6:59 pm
by FBW
disco2hse wrote: Fri Jul 16, 2021 8:40 pm Absolutely brilliant.
..thank you but don't overdo it.
The thick folder of documents that was always carried with me led to a relaxed acceptance.
The official sea blessing was thus, more or less, only a matter of form.
Today we still tinkered a heat protection for the clutch slave cylinder. I meant it a little too well when I put the exhaust system up high. The thing is getting really warm around the heart. With the fender everything seems to be fine ...
..and the front has been beautified! Image
... and even more for the eye :D
Evil tongues are now saying that I had cut up a US flag and asked where the stars went.Image
... no, you can buy something like that even without stars. That fits perfectly with the red candy on the dormobile roof. Image
A few "dirty jobs" have to be done before the interior is finished.
In the fund there was still a roof rack. The noble Swiss product has to be adapted a little for the Sandy.
Cut through at a strategically favorable point ...
"Clamping sleeves" tinkered that are inserted into the pipes. So they center themselves as if by themselves. That makes dodging together a lot easier. Image
Then the rust spots are blown with some paint.
There are still a few ideas that need to be implemented on this thing. Only when all of this has been done will I have the carrier re-galvanized ... or beautify it with stovepipe silver Image
... then I took care of the bracket for the Foxwing. Due to the Dormobile roof, all the usual fixings are ruled out.
Then the flex and the welding machine have to work ...Image
At the front there was a console on the roof rack. It has to protrude a little so that the Dormobile roof opens without collision.
The solution chosen at the back has the chance to defy longer hopping paths ...
I'm afraid the thing will have to take on a few more useful functions. In order to be able to implement this with welding technology, the support is only galvanized when it has reached an advanced stage of maturity. Until then, a touch of black ensures that it doesn't look quite so raw.
And the Foxwing can hang out ...
The support profile of the Foxwing is quite stable, but on the Sandy the wing is now firmly fixed at the front and the back. You can bend them significantly with little force. If you do it rhythmically, it really swings up. It is quite conceivable that this could happen on the motorway due to the airstream ...
But the tooth was also pulled :D
With some regalia the Sandy doesn't look so "sterile" anymore ... it will!
greeting
Frank
Posted: Mon Jul 19, 2021 2:28 am
FBW wrote: Sun Jul 18, 2021 6:59 pm
Ahh but the burble of a V8 stirs the heart! :lol:
I have no idea what the folder is :?:
However, there are few builds that would come as close, and I am certain it is better now than it was new. So credit where it is due.
Posted: Tue Jul 20, 2021 2:14 pm
by Mic4x4
Brilliant work! I have been watching your postings form some months already and it's great to see the passion and preciseness you're undertaking in every single step!
Posted: Wed Jul 21, 2021 8:10 pm
by FBW
disco2hse wrote: Mon Jul 19, 2021 2:28 am I have no idea what the folder is
Sandy has never been registered in Germany. So a so-called full acceptance is necessary. I think you can imagine that the German authorities take it very carefully. This is not an issue with a standard car, but with such an exotic car there are many questions and not only answers but also documents are needed. In the folder are brochures from Sandringham, Dormobile. Technical documents for the trailer coupling and much more. The good man from the TÜV who does the acceptance is always happy when he has documents to file ...
Mic4x4 wrote: Tue Jul 20, 2021 2:14 pm Brilliant work! I have been watching your postings form some months already and it's great to see the passion and preciseness you're undertaking in every single step!
Hi Mic,
I am pleased that you like the report and my work
There are things that cannot be done better Image
But copy! Image
I deliberately made the area between the canister and the lower tailgate a few deeper than on the original. Because I want to attach the bulwark to the roof rack. Another box should go into the free space. How exactly. ... but I can think of something else.
The Dormobile sticker is of course as wrong as possible :oops:
Oh yes, here is the link to what needs to be copied :D
https://www.stage1v8.org.uk/album/Frank ... 1.JPG.html
greeting
Frank
Posted: Fri Sep 03, 2021 12:44 pm
by tomo_
great job!
Posted: Wed Nov 03, 2021 7:55 pm
by Mik
Looks fantastic Frank! Btw the bottom grille originally covered the full width of the "indentation" ;)
Posted: Thu Nov 04, 2021 6:34 am
by tomo_
I believe I've got kind of GEN heating valve bracket for MOD type air filter. Found it while sorting parts for my Stage 1 . Frank, If you are interested I can post the pics .
