New Series 3 Stage 1 owner
V8_Disco
Post by V8_Disco »
Cheers Rob, link herehttp://forum.landrovernet.com/showthread.php/187720-Part-Number-for-Sun-Visor?p=1448223
Aidan
1982, Stage 1 SW LPG
1999, Disco 2 4.6 Stage 1 Heads ES Multipoint LPG
1976, 88 SW
1973, 88 Truck Cab
blueboar
Post by blueboar »
If you look at page 7 at the sun visor near the bottom part number BA131
http://www.bearmach.com/partscatalogues ... sories.pdf
Is this what you want??
bb
V8_Disco
Post by V8_Disco »
Thanks BB, Its the kind I have seen before,
The one on this truck attaches/overlaps the Safari Roof
Aidan
1976, 88 SW
1973, 88 Truck Cab
landiman wrote:The last owner fitted a 88" hard top which was surplus in a workshop in Kuwait, The hard top was originally taken off an 88 that was destined for the Kuwaiti army as they only run soft top's. It's not a bad conversion and works quite well...... i spotted another with this conversion in a classified advert last week, so it's not the only one.
Interesting. Never thought of doing that before and never seen anything around here like that.
landiman wrote:As for the thing hanging from the grille i think it's the last owners attempt at a radiator muff... it's not on there now, but i've had to make another from plastic for running in the cold weather here. A couple of weeks ago we had a lot of snow and as i'm part of a 4x4 i was running about in the bad weather freezing my bits off cos the temp gauge never got off cold. After fitting my rad muff it warmed up lovely.
I thought it might have been a muff or something. Again, we never see things like that around here cos it usually doesn't get cold enough. I vaguely remember there being a LR muff that attached to the front grill. It had a mid section that had dome clips that you could use to open or close the muff.
V8_Disco
Post by V8_Disco »
Rob, was the visor fitted in the UK? realy cant find another one
1976, 88 SW
1973, 88 Truck Cab
landiman
Post by landiman »
I've no idea.... it might have been fitted abroard, but i'm certain i've seen similar fitted to series 2's and truck cab versions. :?
http://s850.photobucket.com/albums/ab66 ... an/Series/
Series 3 stage 1 109( now off to usa)
V8_Disco
Post by V8_Disco »
Thanks Rob, every little helps, called Dunsford and they did not recognise it
A
1976, 88 SW
1973, 88 Truck Cab
