Hi guy's just wanting to know where I can get my hands on a centre dash like the one in this earlyer post??
Or can anyone measure theres so I can make one?
Also is there just the diff lock light, park barke light and brake fail light in them or is there more??
http://www.stage1v8.org.uk/phpBB2/viewt ... entre+dash
Adam
Wanted centre dash
Wanted centre dash
One Life Live It
1982 Stage 1 V8 wgn
1982 Stage 1 V8 wgn
I'd like one to.
The centre panel would appear to be a somewhat unique order for the NZ Army. I haven't found another Military listing for it. There are two similar panels for UK and other forces (without the big dial). The side panels, lower skirts, seals, trims, screws and captive nuts all available new.
I'd like a NZ unit, but would prefer the Australian Army version which allows for more ventilation.
The hard part is the curved base with folded lip. I don't have the time, otherwise I'd make a wooden jig up from a UK item so the lip can be dressed without distorting the panel.
If you swap both end brackets over, you can have the extra ventilation as per the Australian part. Though you loose some depth. Any switches or gauges have to be closer to centre.
