Bushes
robert
Bushes
Post by robert »
Are the bushes same as for normal series 3?
If no what are diffrences?
Robert
stirlsilver
Post by stirlsilver »
I'm pretty sure they are the same... Just take some measurements of the ones you have fitted and compare them with any that you are going to buy... But I recommend you get nolaphane bushes. Makes life Soo much easier!
robert
Post by robert »
Thanks for response, I wish I can measure it. I'm asking as I'm in UK at the moment and car is in Poland, it makes buying spares bit dificult. Just a bit. ;-)
Regards
robert
PS What is material of bushes which you mentioned?
stirlsilver
A nolathane bush is a type of Poly bush. It doesn't have the steel sleeve on the outside so it can't seize into the leafs. They come in two halves with a inner steel sleeve.
This site should give you some insight:
http://www.redranger.com.au/why.htm
Andy Dawe
Post by Andy Dawe »
I used an orange polybush set polybush sell differing grades of hardness depending on colour. Orange was recommended by Chris Perfect when I bought his parabolic suspension. Easy to fit and/replace and 2 yrs on are outliving the originals easily.
