Restoration
Re: Restoration
Post by Cliff4WD » Mon Jul 08, 2019 6:07 pm
Pressed on today.
I decided to tidy up the chassis ready to refit the gearbox. The galvanised chassis is like new under a few years of grime. I already gave it a pressure washer before removing the gearbox, but it looked a bit dirty still, so gave it a wire brush and then painted it with some oil. I figure a bit of waterproofing can only be a good thing though strictly speaking, quite unnecessary.
With a bit of oil...
Having started, I thought best to carry on and have the engine out too. So radiator first.
Viscous fan...
...and after a lot of contorting and knuckle skinning, got the exhaust, earth strap, alternator, breathers, fuel line, etc. freed, set up the crane amd started the engine lift
With the V8 out of the way I'll finish off tidying the chassis and sort brake lines, etc.
The V8 is on the dolly ready for overhaul.
I'll probably get the tub off next and focus on the chassis, brake and fuel lines. Axles and springs too. Mind you, I want to get the gearbox back in place now it's rebuilt so that I can fit the bulkhead. So much to do, decisions, decisions. Lol
Re: Restoration
Post by Cliff4WD » Sat Jul 20, 2019 5:36 pm
Not been much progress since lifting the engine, it's been sat on the dolly in the way, so really needed to shift it until I can work on it. I want it in my workshop but how to get it up over the step? Came up with the one man two stage shift-it plan.
Put a board covered pallet in front of the workshop door step and used the crane to lift the engine up off the dolly, put the dolly on the pallet, and lower the engine back onto the dolly which can now be wheeled straight into the workshop.
What a faff! Not so easy shifting heavy stuff on your todd.
Now I need to reorganise the shop amd make some room for me!
Re: Restoration
Post by Cliff4WD » Sat Jul 20, 2019 5:44 pm
Need to do the same with the spare LT95 currently sat behind the vehicle and again, right in the way! Need to make another dolly.
Fish
Re: Restoration
Post by Fish » Tue Jul 23, 2019 2:50 pm
I've just ordered a load of casters to make myself some dollies in advance...
Re: Restoration
Post by Cliff4WD » Tue Jul 23, 2019 10:18 pm
Essential for shifting heavy things IMO. I made another one a couple of days ago and should be getting on with it, but heatwave here has slowed me down until it cools a bit.
Re: Restoration
Post by Cliff4WD » Sat Aug 03, 2019 5:57 pm
Not too much to update on as I've been forced to rest up a bit. Also, I've been looking at it and trying to decide next steps, however, it qets a bit overwhelming if you look at everything that has to be done together, so back to the elephant consumption strategy; 'one bite at a time'. :lol:
The first thing I needed to do was get the spare gearbox out of the way. I had made up another dolly for this and so transferred the box onto the dolly. This way I can roll it out the way as needed until I have space for it elsewhere. I also shifted doors, bonnet, etc. that I currently have stacked up beside it, and several boxes of dismantled parts sat in the tub. Having made space I could get the sides and the rear door off.
Still a mess but can work on getting the tub off now.
Moved on to removing rear lights. Found the typical PO DIY spaghetti wiring nightmare
God help us, flippin mess. Looks like I'll be adding replacement harness to my restoration parts list.
Soon had the lights off. Rusted damaged srews and all. I'll be replacing this lot too as a mix of Lucas/Wipac/Unknown and all a bit past it.
At this point, curiosity got the better of me and I was distracted by the painted cappings. I have a spare set PO bought that came with the vehicle, however, I'm thinking a bit of paint stripper will get the paint off easy enough. So what's under the paint?
Doesn't look too bad to me.
I think before I take the tub off, I'd like to get the newly rebuilt LT95 back in place and the bulkhead refitted. I have to paint the bulkhead first before it goes back so have decided to clean up and key the galv and then paint with epoxy primer. There's quite a bit of work to do on the bulkhead before it will be ready for its colour coat so that's next step.
I still haven't decided on colour, keep it Limestone, Green, or something modern and shiny?
Re: Restoration
Post by disco2hse » Sat Aug 03, 2019 8:38 pm
Wiring looks better than what I found in the back of mine.
Re: Restoration
Post by Cliff4WD » Thu Aug 08, 2019 10:50 pm
I was not very happy with the quality of the galvanising of my bulkhead, it had a lot of dross left on it and a pretty rough surface, however, it is well covered with zinc so should outlast me. Today I've been cleaning and keying the surface ready for painting. After washing it down with a mordant solution, I'm going to give it 2 coats of epoxy primer, then fill the dings and dents before moving on to the next stage in the painting process. I have also been re-tapping the few nutserts and windscreen pivot threads that were clogged up during the galvanising process.
Re: Restoration
Post by Cliff4WD » Fri Aug 16, 2019 5:13 pm
Having had to wait for materials to arrive (order mix ups and delays), I've now been able to resume work on the bulkhead. Having sanded it to improve the surface and provide a key, I then gave it a mordant wash to chemically etch it ready for priming. Washed it and scrubbbed it to ensure surface was clean, then setup in the 'pop-up' paint booth :lol:
Then attacked it with the spray gun - 2 coats of 2k epoxy primer. I used HB body 989 4:1 with the HB body thinners. First coat wasn't great as it came out the gun too thick and spattered on, something a bit wrong with my regulator setup and air pressure was too low. Sorted it out and then got better results although a few annoying runs. It has to be flatted back anyway for next stage so not a big deal.
Now to let it dry and cure before filling the few dents around the gutter. Whoever was resonsible for hacking off the gutter when this bulkhead was first repaired back in the 1990s and doing the damage that they did should be shot!
Gus
Re: Restoration
Post by Gus » Sat Aug 17, 2019 1:00 am
Looks great. I am about 12 months behind you with my firewall repair (just removed it) but I have no experience with paint over galv. How heavily can you sand? I assume you don’t want to go too far and break through the galv coating? Gus
Gus
Re: Restoration
Post by Gus » Sat Aug 17, 2019 3:56 am
Re: Restoration
Post by Cliff4WD » Sat Aug 17, 2019 4:43 pm
You just want to degrease and key the surface so that the paint will stick. Lightly sanding with 180 grit to remove any dross embedded in the zinc and degrease/etching with a mordant solution, e.g. T-wash seem to give the zinc a surface suitable for painting. The sanding doesn't need to be done too hard, just let the sander do the work under its own weight. Any small areas where you do cut through the zinc and expose bare steel are not the end of the world if then covered with epoxy. I used 2 pack epoxy primer as this has good adherence properties and is approved for painting onto galvanised surfaces. I guess that a heavy zinc content primer could also be used to repair any damaged areas of the galvanising.
Strictly speaking, I could have just primed the bulkhead rather than galvanizing it too but I decided on double protection so that it will long outlast me.
Re: Restoration
Post by disco2hse » Sat Aug 17, 2019 6:28 pm
Also, in NZ we don't have salt on the roads when it gets icy. So less chance of rust.
Re: Restoration
Post by Cliff4WD » Wed Sep 25, 2019 5:54 pm
Well, after being slowed by some chronic health issues and the distractions of the Peterborough LRO show, and a few probs with the Discovery 2 to correct, it was back to the Stage 1 restoration.
I've completed the skim filler, sanding, and given the bulkhead another coat of epoxy primer.
Today I started applying seam sealer.
I can't wait to get this finished and move on.
Re: Restoration
Post by disco2hse » Wed Sep 25, 2019 7:27 pm
Looking good though. Better than when new.
