Battery cables
Battery cables
Could anyone take a quick look under there LR and tell me where the battery earth cables from. Know they come in the back of the seatbox, but not where the other end goes to (I know it could technically go to pretty much anything metal, but I'm trying to get it run right)
Re: Battery cables
Mine bolts onto the outrigger just behind the seatbox.
Re: Battery cables
Cheers, have done the same. Looks quite tidy
Do you have only 1 earth front engine/box to chassis? I've got one at the front of the engine to be chassis. Is there another anywhere
Waiting the battery to charge, then hopefully things work ..l maybe
Re: Battery cables
Yeh, just one next to the engine mount, good luck with the start up
Re: Battery cables
Sort of a success
There was no smoke so that's good
Sme issues to investigate tomorrow though,
Engine tries to start on first position of key
No brake lights
No fuel pump
No charge light
No heater
No washers
No horn
Cold start and main beam warning lights wrong way around
Hazards and fogs working, which were a nightmare to work out. Indicators, wipers, lights,flashers, starter, oil pressure etc all work.
Can't test temp or fuel yet
So don't think any of the non working bits are major - back to it tomorrow
No brake lights
No fuel pump
No charge light
No heater
No washers
No horn
Re: Battery cables
you may have just got your ignition switch wired up incorrectly??
