MS80 Carberettor Adjustment Tool
ProofNZ
Post by ProofNZ »
Good morning gentlemen - any ideas where I might be able to source one of these in NZ?
Have tried Landroverparts.co.nz - waiting on landroverspares... any other ideas? Thanks.
NZ105R
Re: MS80 Carberettor Adjustment Tool
Post by NZ105R »
I'm guessing MS80's are the original Carbs.
Broaden your search. There are loads of these tools around.
I got some for my Rover SD1 years ago.
These same tools are used by many British cars, e,g Rover, Triumph, Jag Etc..........
Some will turn up easy enough :D
Have Fun :!:
Mark
1986 Stage 1 NZ Army
1957 Rover P4 105R
ProofNZ
Post by ProofNZ »
Ah, I thought they may be specific to the Stage 1.
Thanks. Will keep hunting around.
NZ105R
Post by NZ105R »
Mark
1957 Rover P4 105R
ProofNZ
Post by ProofNZ »
Thanks for that - thought I believe that the Stage 1 has the CDSE carb in it - later model?
NZ105R
Post by NZ105R »
I'm pretty sure it's the correct tool but the description the seller has written is all wrong.
Here is another one for 175CD V8 Rover engines 1982-1985.
http://www.rimmerbros.co.uk/Item--i-RX1222
Mark
1957 Rover P4 105R
ProofNZ
Post by ProofNZ »
Yeah, looking at the service manual, and his image - they look identical.
Have purchased. Thanks for the heads up.
ProofNZ
Post by ProofNZ »
Hrm... ok folks - how do I go about definitely identifying what Zenith I have in there? The hexagonal tool doesn't seem to be going into anything - but want to confirm what tool I am meant to be using before I push anything.
:lol:
datsta
Post by datsta »
Look on the top of the carb. You should see 175 CD and that needs the tool to hold the diaphragm so you can adjust the needle height with the tool. Otherwise the adjustment might rip the diaphragm.
I have one 175 CD-2 that has the mixture adjustment below the carb and needs no tool.
Cheers.
Stage 1 V8 hardtop s/w.
ProofNZ
Post by ProofNZ »
Is the tool you use got a hex end, or a bladed end?
datsta
Post by datsta »
There are two sorts, mine is the one on the right in this picture
The bottom has a slot that matched a blade in the carb.
Cheers.
ProofNZ
Post by ProofNZ »
Yep. One on the right is the one I need.
Where did you get yours? Seems to be a bit of a challenge locally...
datsta
Post by datsta »
I got it from www.dingocroft.co.uk part number ZZB25860
Here's the link http://www.dingocroft.co.uk/cgi-bin/ss0 ... ACTION=Go! £6. 49
Cheers.
ProofNZ
Post by ProofNZ »
Picked one up from - http://www.csl2003.co.nz/contact.php - they had multiple in stock.
