oil pump confirmation of sender positions
Can somebody please confirm l have labled the oil temperature, oil pressure transmitter and oil pressure switch correctly in the picture.
l am sure l have the oil pressure transmitter is labled correctly . its the oil pressure/temperature switches l am not 100% sure on.
now before l am told to check the manual (page 1F-05) - l have, which l why l have listed the part number. l am confusing myself laying upside down looking at it and refering back to the manual.
working out the logic to why my oil pressure gauge now reads 60psi and never drops.
plan, once correct parts are confirmed, replace oil pressure transmitter to ensure thats not at fault,
if that does not solve - look at pressure relief spring.
thanks
sebking
sensors
Post by sebking »
looks ok to me - (I don't have the oil temp one or tbh have seen one of those before there, certainly on the SD1 that's on the sump)
thanks seb,
l do not have a oil temperature gauge which is why there is no cable on it.
will be installing a gauge for it in the future
Looks correct to me. I do have the oil temp gauge and I use the sender as shown with an early RR oil temp gauge to match the original pressure gauge.
thanks for the response
l have ordered a new sender from Rimmer Bros
£27.54 + p&p (better than paddocks)
hopefully this will sort the problem
Correct RR gauge if you are looking for an addition :D
http://www.ebay.co.uk/itm/LAND-ROVER-SE ... 45fc2237dc
Thanks for the highlighting Another eBay potential purchase! Need to stop spending money on the truck!!
Anyways- l have finally got a working oil pressure gauge again! Much relieved.
Used rimmer bros. great service!
