seatbox lid layout
seatbox lid layout
Could someone confirm that the lids on the centre and RH (as sat in vehicle) are screw down type and the LH one is on a swively catch
Seems odd to mo to have the battery under one with a scre down lid, but looks to be how mine was (dont have the lids and lots of po messing so want to check) - if so me thinks an accessible battery kill switch is a good plan
Greenmobile
Post by Greenmobile »
Yep, just as you say.
I've a battery isolator connected through the front of the drivers (RHD) seatbox at the moment.
Cheers.
thanks - not one of LR's best plans that :shock:
On mine there is a fuel tank under the drivers' seat (LH) and the batteries are under the passenger seat (RH). Also have a fuel tank in the rear. Suspect it has to do with that.
db
Site Admin
Post by db »
Mine has a cover like this:
http://stage1v8.org.uk/battery_cover/index.html
db wrote:Mine has a cover like this:
Have you got a 110 seatbox ... looks very 110 V8 ish does that (I defiantly dont have them)
db
Site Admin
Post by db »
I think it's the original seat box and it's the original paint colour but I can't be sure what might have happened before I owned the vehicle.
Late stage 1 then?
what year?
db
Site Admin
Post by db »
5988 wrote: what year?
It's a late '82 Y plate.
Kiwistage1V8
Post by Kiwistage1V8 »
My 110's seatbox is the one as the one in my stage 1, except for the cubby under drivers seat, and size of lid covering the battery box. (will be the same as disco's seatbox). I was going to remove the front fuel tank, and rivet in the cubby on the stage 1 as it had mint lids and panels.
The donor seatbox I got and stripped for the panels was from a civillian stage 1, but I never did it. Now I'm stoked because the seatbox in the 110 is pretty sloppy, so will rivet on the better panels and make it good.
It's even better because I scored some high back defender seats, and the bases lift out to get into the boxes under the seat! very posh. bahahahaha
Stop Global Whining.
Greenmobile wrote:Yep, just as you say.
Cheers.
Any chance of a pic, of the RH one,
I cant see any evidence of where mine has been screwed down (no obvious holes for screws) and no holes in the front for a catch to be removable
now confused
Greenmobile
I'll see if I can get something before it gets dark. :)
Greenmobile
Apologies! I could have sworn the RH cover was screwed down but oh no....as you can see below.
HTH.
Cheers.
interestingly that is the layout the manual shows, but my seatbox doesnt have holes for that or hoes to screw the cover down with :?
Will go with that set up I think
