Engine Swap
Don't forget the spigot bush in the back of the crankshaft (549911)
sebking
got one of those
Post by sebking »
sebking
Just in case
Post by sebking »
A few observations if mixing bits. The SD1 timing marks are in a different plan compared to a stage 1 or indeed a range rover, might save a few confused thoughts. Also for reference the high and low marks are in a different place on the dipstick...!
sebking
today also
Post by sebking »
removed left manifold (well the boy did) cleaned up the stage 1 damper assembly and water pump pulley that arrived this week and gave a coat of satin black.
Dipstick tube in and a few other bits. the hilarious bit was turning the engine by hand and seeing the red caps installed by Land rover that block the spark plug tubes for storage flying in all directions - didn't expect the seal to be that good - I guess that means there is some compression!
Chris_G
Post by Chris_G »
Is there anybody who can tell me where I can find (on the internet) composite gaskets for heads and inlet manifold?
Chris_G
1983 Series 3 88" 2.25 Diesel
1981 Series 3 109" Stage One V8
2008 Defender 90
Alicerover
Post by Alicerover »
The company you need is J E Developments. There is a web site just make sure you get the right one
Spen
sebking
more progress
Post by sebking »
manifolds cleaned and studs replaced where needed, no more bits left on the old lump now to move over. Have just ordered a couple of missing bolts and new clutch kit, plate was quite worn and while the engine is out it seems mad not to replace.
sebking
More work
Post by sebking »
Chirstmas and work got in the way, but engine now built up with manifolds etc, ready to swing in tomorrow. Bad news was that I broke a fuel pipe on one of the carbs...
So looking at recon costs I've gone an ordered a new set!!
sebking
Carbs
Post by sebking »
For reference Burlen cheaper than anywhere else.
sebking
Engine in!
Post by sebking »
It's in, now for connecting it all up!
Took some hours to get the 'box and engine lined up, ended up removing the bumper as the crane was fouling it and couldn't get the last few cm onto the splines.
Well done. A major milestone :)
sebking
lack of progress
Post by sebking »
nothing much - too busy at work and other house projects. but a box of shiny new carbs arrived yesterday - very nice (never had a new carb before!)
Seb
sebking
Nearly... but so far
Post by sebking »
All in, watered and oiled. Oil primed, front panel back on, starter connected.
Spun the new engine on the started, oils lights on and off.
Scuppered yesterday by a water leak which took a while to find so didn't get a change to time up and see if it fired.
My dodgy repair to the old carb held fuel so will keep these on for starting up and swap as soon as everything is running.
Make sure you have a video running to grab the first start up :)
sebking
b*gger
Post by sebking »
one of the exhaust manifold gaskets is on back to front so it sounds like a train. Just spend the last two hours trying to get the damned thing off again.
(it has started though!)
grrrr
