Engine Part NO's
5988
Engine Part NO's
Posted here instead of in the other thread so it can be later found if anyone else looks (N.B there for a RRC 3.5 ...which is mostly the same as the S3 V8 as far as i know)
Mains Std- RTC1718 (set)
Big Ends Std- RTC2117 (set)
Camshaft -ETC6850 (1x)
Followers - ERC4949 (16x)
Rocker Shaft -STC154 (2x) -Note the way arround there fitted - get it wrong they get no oil :shock:
Timing gear -Cam-610289 (1x)
Timing Gear Crank ERR2958 (1x)
Timing Chain - ERC7929 (1x)
Front Crank Seal -ERR1632 (dont think it was in the bottom end set)
Bottom End gasket Set -RTC3306 (1x)
Head Gaskets Set -RTC3337 (for both heads)
Other Bits
Oil Filter Err3340
Rocker Covers Gaskets -602512 (2x)
Flame Traps - 603330 (2x)
Breather Filter -606168
Plug Leads - rtc6551
Fuel Filter - 660l
Carb Diaphrams - JS499L (2x)
Carb overhaul kit -aau2967 (2x)
Timing cover gasket - ERR4936
Air Filters - 605191(2x) - RRC Type of filter not the big canister one
