Putting a S3 PTO in a Stage One
JimB
Post by JimB »
Technically not especially gifted here. But I have a decent mechanic. Here in Indonesia.
Will a PTO off a S3/Swb fit onto the LT95 transfer case. I looked at it. It looks ok, albeit a tight fit. I just want to know if the transfer case PTO plate is the same?
The bloke wants a fair bit for the PTO and I don't want to find out it doesn't fit. He's quite far away so I can't physically inspect the PTO and measure it.
All advice/input welcome!
Driving an '83 limestone Stage One
JimB
Re: Putting a S3 PTO in a Stage One
Post by JimB »
This is the PTO housing.
Considering that the parts list doesn't even list the same gasket for the two variants, I'd say not.
Mik
Post by Mik »
Pretty sure thats a No - but with modifications everything is possible
Michael
1965 109 FC SIIA
1982 109 V8 SIII CSW Stage One
1982 109 V8 SIII HCPU Stage One
1990 RRC Vogue SE
JimB
Post by JimB »
Thanks gentlemen. I'll stick to my hand winch, snatch block, and assortment of ropes. Local blokes say the PTO winches can be dangerous if you are not super careful. And I'm not super careful.
So yeah. Series III won't go in. Pretty much everything is different to an LT95 PTO output.
I have a PTO winch on mine and it is fine, safetywise.
