Looking for
Rear light wiring covers, both sides
Set if tailgate chains
Hazard light switch (can get replacements but would like LR one)
Fog light switch
Flywheel cover
The bracket the lower steering column trim attaches to (the trim with the fuse is in it)
Choke cable bracket that bolts to the side of the carb
Various stage 1 bits wanted
Re: Various stage 1 bits wanted
The original hazard warning switch is a Lucas one, still commonly available on ebay, eg:
http://www.ebay.co.uk/itm/Lucas-Hazard- ... 418469fb23
Not so the fog light switch, which is also Lucas. Since it's a pretty simple switch, there's lots of similar alternative replacements that'll fit but the nearest thing I can find to the original (in looks) is a 'military' (apparently) one - PRC2888 - widely available, eg:
http://www.ebay.co.uk/itm/Land-Rover-li ... 1c438a4186
but, mysteriously, although it seems to contain a bulb holder, the knob is absolutely opaque and so does not light up, so to be legal you will have to wire in a separate warning light - unless you already have the orange knob (which will screw right on to replace the opaque one) - might need some extra/altered wiring to make switch light up (and a bulb of course)
