Can't find radiator drain plug!
arcticrover
Post by arcticrover »
I've looked all over the bottom and exposed sides of the radiator to find the drain plug that is described in the manual. Where the heck is it? Do I have to remove the radiator to get at the plug?? :?: That would be retarted!
Basil
Post by Basil »
Hi mate you might find that if the rad has been reconditioned at some time that it has dissapeared, thats what happened to mine, but did not notice till i wanted to drain the system again some time later, if you can't find it just pull bottom hose of.
Basil
