Does Anybody Know?
stretchlandy
Does Anybody Know?
Post by stretchlandy »
As you might know, I'm looking to fit two axles on the back of my landy. I've just measured the leaf springs at the back, and calculated that the wheels would have a gap of around 20 inches between them if i kept the existing measurements. Obviously not that great for the wheels when going around corners! So the questions are threefold :
1) Has anyone done coil conversions on their motors and do they have pictures.
b) has anyone done twin rear axle conversions to their motors at all.
3)does anybody know anything about this :Image
It's a crop of a picture from landroverclub.net, apparently a LR special vehicles machine.
1977 101 Forward control
1982 Stage 1 Hardtop (under deconstruction)
1998 Series 1 Discovery V8i
www.lr-mad.co.uk
Basil
Post by Basil »
Hi stretchlandy, what you need to look at is a sandrigham six as these where the stage1 six wheeler's that landrover built and they where leave sprung all round.
It is possible to build it with coil spring's on the back and use a standard 109 inch tub, you have to cut a bigger wheel arch but i have seen it done.
Do you intend to make it 6 wheel drive or is it going to be a 6by4, foley make a wonderful compact drive though unit to give you power to your rear diff that you can engage and disengage on the move, but i have no idea how expensive this is.
Basil
Landrover, If it don't leak oil, it's ran out.
Stage1 station wagon, 3.9 V8, galv chassis, parabolic's, lpg
stretchlandy
Hi Basil, Thanks for that, The plan at the moment is to go 6x4 initially, as i don't intend to use it offroad (more as a load lugger) however 6x6 will be kept in the frame. I believe the foley unit is around 5 grand, and depending on the old budget, it could get a late inclusion near the end of the project. (i need the time to sweeten up the wife). I'll look further into the sandringham six machine meantime, as this could provide valuable help in the layout of the chassis. :)
www.lr-mad.co.uk
martin hughes
Post by martin hughes »
The vehicle shown was for sale a while ago in lro and the other mags. I think the springs one one axle are closer together allowing them to "overlap" the other axle. thus allowing the wheels to be closer together.
1982 109 V8 Station Wagon
1965 88 Short Wheel Base
stretchlandy
yeah, i was wondering about the leaf spring setup.
Anybody know someone with a sandringham six?
www.lr-mad.co.uk
Ginga
Post by Ginga »
I found this in a classic search
Its a pdf document. On Page 3 is a 6 wheel stage 1
http://images.classiccarsmagazine.co.uk ... /nov05.pdf
Ginga
PS if anyone has or knows of a Stage 1 HCPU for sale let me know :D
Theres always a way !
onno wielinga
Post by onno wielinga »
i do believe the springs of the frontaxle are in the position of the 109; the rear axle has the springs in the position of the 88 inch cars so they can overlap and go beside each other. the position of the springs on the axles could also be the other way round.
samro
Post by samro »
"The very difficult we do immediately the impossible takes a little longer!"
1985 Range Rover V8 Auto [Rachel]
1981 Stage 1 V8 S/W [Custard]
1972 SIII 88" D S/W [The 88"]
stretchlandy
Thanks all.
I managed to get talking to someone with a sandringham six type vehicle, who was able to mail me a picture of the suspension setup.
www.lr-mad.co.uk
martin hughes
can we all have a look?
stretchlandy
of course you can. :D
just visit this page for a comparative view of two different (leaf sprung) double rear axle setups.
If you have any pictures of your vehicle please send them in, my website's a bit sparse at the minute! any Land Rover vehicle (as well as stage 1s and sandy 6s). thanks.
www.lr-mad.co.uk
