Breaking stage one V8 Truckcab
Re: Breaking stage one V8 Truckcab
Hi Bryan
Just spotted this thread. I'm on the lookout for the following for RHP 175R
One heater pipe (aluminum ones)
Heater valve and bracket
Thermostatic air intake trumpet assembly with brackets
Carb breather pipes
Front badge
Front mats
Can you help?
Emrys
Carb breather pipes
Front badge
Front mats
Can you help?
Emrys
Just a couple of things:
One heater pipe (aluminum ones) << Secondhand should be ok for this.
Heater valve and bracket << Usually made from unobtainium, hence the other thread asking for people who would be interested in a short run of bespoke valves.
Thermostatic air intake trumpet assembly with brackets << Flux capacitor comes with that?
Carb breather pipes << You can get this from an industrial hose supplier for chips
Front badge << Secondhand is good, if it's still still there
Front mats << As above. Assume you mean the heavy duty sliced up tyres?
