Stage 1 V8 Forum Index Stage 1 V8
A place to discuss the Stage 1 V8 Land Rover
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Military switch type panel
Post new topic   Reply to topic    Stage 1 V8 Forum Index -> Technical Discussion
View previous topic :: View next topic
Author Message
Mrs Bingham
PostPosted: Fri Jul 30, 2010 3:26 pm    Post subject: Military switch type panel Reply with quote
Can anybody confirm how the military spec switch panel attaches to the bulkhead?
The standard Stage1 has a central switch panel which consists of two side panels and a central trim. I want to insert a flat panel between the side panels much like the military spec ones thus spreading apart the existing side panels. If I spread the side panels effectively the screw holes line up with thin air on the vent panel (where the air vents are). Obviously I can make up a bracket to suit but I’m interested to know how Land Rover intended this.
Thanks…
_________________
Back to top
View user's profile Send private message
PostPosted: Fri Jul 30, 2010 8:34 pm    Post subject: Reply with quote
On mine there are four screws (two on each side). That's all. No other brackets at the top or bottom.
_________________
Back to top
PostPosted: Fri Jul 30, 2010 10:56 pm    Post subject: Reply with quote
Which Military panel?
The basic addition to Ser III doesn't attach to the bulkhead in any way. It mounts to the vent panel under the top dash rail.
The standard UK Military panel deletes the RH vent hole, the Australian version doesn't. In any case these all require 1/16 holes to be drilled in the vent panel.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Stage 1 V8 Forum Index -> Technical Discussion All times are GMT
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
